Thread: Printing With TPU
08-18-2019, 08:13 PM #1
- Aug 2019
Printing With TPU
I’ve tried printing with TPU using 225 degree nozzle and 60 degree bed. I’ve tried slowing it down to 15mm per second but i’m getting a very spotty result.
Any suggestions?
08-19-2019, 09:41 AM #2
- May 2018
- 566
Gravity feed spool holder with roller bearing so filament move with virtual no force required. If you extruder drive is not just spring loaded, adjust the tension with a test print running. Loosen it, and then very slowly tighten it until the filament starts moving.. then a air more. Thats it..
No retraction
The above is for Ninjaflex, Cheetah is much stiffer and not as much a problem.
Good luck it takes a lot of fiddling but can be done.
08-22-2019, 05:35 AM #3
225 is nowhere near hot enough for most tpu, and 15mms - depending on what kind of estruder you have - is pretty fast.
For filaflex I think I ended up printing at 250c and 20mms on my i3 - and that's a direct drive !
Also, having your printer upside down, probably isn't helping ;-)
