Results 1 to 10 of 14
Thread: I want to buy a RGB 3D Printer
08-03-2019, 06:13 AM #1almog123xGuest
Looking to buy a 3D Printer which can print in RGB in reasonable prices
and i want to make sure i can print big projects such as skulls/masks and more " wristbands etc etc" and when i print them so there will be no strings on the project if possibleLast edited by almog123x; 08-03-2019 at 07:32 AM.
08-03-2019, 09:22 AM #2
what's your budget ?
There are a number of options, from a full on connex full colour for a couple of hundred thousand dollars, on down to the xyzprinting davinci for around 3000 pounds: https://www.amazon.co.uk/XYZ-Printin...gateway&sr=8-3
Then there are the other options where you add an external filament mixer to a bog standard i3.
palette 2 from mosaic: https://www.mosaicmfg.com/products/palette-2
starts at $500.
08-03-2019, 09:50 AM #3
08-03-2019, 10:36 AM #4
In that case a decent i3 and the top of the range mosaic setup is definitely your best bet :-)
Couple the mosaic with a formbot raptor: https://www.formbot3d.com/formbot-ra...ing-p0022.html
And for under $2000 you've got a multi coplour/multi media setup that will print 400x400x500mm :-)
Check with mosaic people that it'll work with a raptor - can't see why it wouldn't. ut always worth a check anyway.
As far as your other query goes. rgb models - not a clue :-)
Also no idea how you'd go about designing full colour parts eithger - I currently only use openscad and while i can make dual colour/material models. It's just by making the model in 2 interconnecting parts.
For a full colour print you'd need a cad setup that knew about colours. Ask mosaic what they recommend.
08-03-2019, 10:58 AM #5almog123xGuest
sounds great thanks but is there a printer thats already assembled?
so i won't have to mess around with assembling it
and you know i want to buy a rgb printer cuz im not to sure about it but im looking for 3D Models thats RGB Colored so i can use them and just print them away you know any places that got 3D Models?
08-03-2019, 11:20 AM #6almog123xGuest
Here is an example of what i want to print in colored rgb
https://www.cgtrader.com/3d-models/m...rick-and-morty
08-04-2019, 07:52 AM #7
yes the xyz one I linked to. https://www.amazon.co.uk/XYZ-Printin...gateway&sr=8-3
That's the cheapest all in one full colour fully assembled on the market.
It's actually generally easier to print in one colopur and then paint the models :-)
08-04-2019, 08:56 AM #8almog123xGuest
08-04-2019, 08:57 AM #9almog123xGuest
would you be able to answer one of my posts as well? https://3dprintboard.com/showthread....725#post130725
08-06-2019, 06:05 AM #10
From the reviews on Amazon USA, it's not looking good. (Only two reviews, but both one star for the same reason!)
https://www.amazon.com/Vinci-Color-M...ustomerReviews
