07-30-2019, 10:42 AM #1
- Jul 2019
Vulcan Hot End - High Performance 1.75mm Hot End - www.Crucible-3d.com
We developed Vulcan after thousands of hours of printing ending up in failure. We found that current consumer grade hotends just don?t cut it. They leak, they break, changing nozzles is difficult, and some are just poorly made.
Our goal is to overcome these challenges to give the consumer a more reliable longer lasting industrial grade hot end for their printer. Vulcan does this.
Nothing can ruin a great print quite like a blob of molten burnt material. At best a leak with only cause cosmetic issues, at worst your hotend or printer could crash and break. One problem of current hot ends is aluminum threads. Aluminum threads get worn out fast if you change a nozzle and are too easy to strip. When your heater block threads are worn out or stripped nothing can stop a leak.
Vulcan doesn?t have a threaded heater block but rather your M6 nozzle threads directly into our stainless-steel heat break. This allows you to torque your nozzle tighter without risking the fragile threads on your heater block.
While running a high-output print farm we found that time changing nozzles is time where the printer isn?t running and is money lost. Our heat-break and nozzle can be changed in under a minute without removing the complete hotend from the printer. Simply release the heat break nozzle assembly and install another with little to no leveling adjustments required.
Visit us at www.Crucible-3d.com
