07-26-2019, 09:15 AM #2
print speed are entirely dependant on which bit of the model is being printed.
Outer layers print slower than inner layers - for example.
If you go through all the s3d menus - each setting has pop up help text.
Essentially the speed you set is the maximum speed and everything else is a percentage of that.
Nothing stopping you setting everything to 100% - it'll probably look like crap - but you can do it.
