06-24-2019, 08:52 AM #4
nope - looks like you need to insert a piece of 3x2 (3mm external, 2mm internal) ptfe tubing inbetween the nozzle and the heating block.
It's something that just about every printer needs and yet most manufacturers still ignore.
Basically you've got a gap between the heatblock and the nozzle where molten filament is pooling.
Tubing is cheap - look on amazon. But make sure you don't get the 4x2, which is more common and used primarily as filament guide.
