Results 11 to 19 of 19
04-11-2014, 01:33 AM #11
- Apr 2014
No glue, tape, spray, juice....just a good clean heated sheet of glass. I keep the heat on the whole print or the glass will contract and pop the printed part off. Every other print, I give the glass a good wipe down with isopropyl after scrape with a boxcutter blade.
Mendel90, 0.3mm j-head Mk5 1.75mm, and PLA from Diamond Age here in NZ.
04-14-2014, 01:40 PM #12
- Apr 2014
Makerfarm 8" presa i3 J-head MK-IV .5 PLA. Clean glass with Aquanet SuperHold. I spray 2 medium coats. Let dry for 10 min or turn on the heat bed. When done printing pull the glass and let cool. The sound will let you know when it has removed it self.
aBraindDump
04-19-2014, 12:21 PM #13
- Apr 2014
- 19
Aquanet Extra-super-hold hairspray works good for PLA
I am wondering if frosted/sandblasted Pyrex would work for ABS.
thick ABS juice applied to hot Pyrex will bubble and create a rough surface too.
04-27-2014, 04:12 PM #14
- Feb 2014
- 51
Lately I have been using nonscented hairspray on a glass build plate. Works like a charm 99.9% of the time. I don't understand why more people don't do this. It's a really affordable method and seems to work better than anything else.
04-29-2014, 05:32 PM #15
- Apr 2014
- Netherlands
- 76
Acrylic works best for me until now.
I'm just reading the reason why I can't get the hairspray on a mirror work well yet,
thanks Funkymonk, mine doesn't have VA/VP...
05-06-2014, 10:12 AM #16
Is this for use with ABS or PLA?
I have tried different types of tape, and 2 different hairsprays, but NEVER have ABS stick correctly. I purchased a heated build plate from ebay, but it is only that.... still need to figure out how to wire it in and control it in addition to having a better platform for it to be clamped to.
05-06-2014, 11:05 AM #17
- Apr 2014
- 19
I use AquaNet Professional Hair Spray Unscented for PLA on Pyrex glass plate 60-70C.
Works great, part pops off after it cools.
Glass cleaner will clean over spray....
05-06-2014, 11:47 AM #18
- Mar 2014
- 157
I use Elmer's Disappearing Purple Glue sticks... with my PLA prints it sticks so well, the only way I can remove the piece afterwards is by putting the glass bed in the freezer for 5 minutes. After about 5 mins the part just falls off the glass. ABS does well with the glue sticks as well, for me.
05-06-2014, 02:07 PM #19
- Apr 2014
- 19
For ABS, I have found that ABS juice works on Pyrex glass without Kapton/PET tape.
just heat up the glass bed and apply the juice in puddles so that it ends up boiling and leaving a thick rough plastic surface.......Of course it stinks.....
