Thread: Lifting corners
06-04-2019, 02:21 PM #1
- Jun 2019
Lifting corners
Hi Guys
Sorry for raising a common problem.
I browsed the entire internet and can't find the answer
Im printing a box on a Creator pro
Corners are lifting whatever I do
The most popular advises are
1. Use heated build plate - Heated
2. Level the build plate - its levelled perfectly. It sticks. First layer is great. Wrapping starts after 20th layer. Before it looks ideal.
3. Reduce infill - 15%
4. Avoid ABS - tried PETG. Bit better but still bad.
5. Use cover - done
6. Incorrect temperature - tried the full range of temps for ABS and PETG - no difference.
Any reasonable suggestions except using a brim Oklahoma-wide and nail it to the build plate please?
Many thanks
