06-04-2019, 09:36 AM #2
you probably want to increase your z gap.
Ie: make the offset distance between the nozzle and the print bed a little larger.
I usually increase by 0.1mm untill you get a balance between a clean first layer and it not sticking to the bed.
If you calibrate with fairly thin paper this is a common problem.
