Results 11 to 15 of 15
05-13-2019, 08:17 AM #11
Have you found the secret setting of 3D Printing the smaller more detailed models.
If No then Continue.
In my printing of PLA it likes to be printed between 192-202C with a Bed temp of 40-60C.
Depending on your 3D Printer the start speed can be a 30-50% as compared to the 100% set in the slicer as full speed.
After the first layer has printed you can increase the print speed. I can print from 72-86% near perfect Models quite easily though have printed faster with a few Print flaws.
I have in the forums uploaded my Cura's profiles they include Cura 15.04.6 - Cura 4. An have used other slicers thou continue using my trusty Cura slicers.
Again here are my Cura Profiles
05-15-2019, 03:18 PM #12
- May 2019
I run 210 on my nozzel and 60 on my bed for hatchbox pla. You may have a bad slicer
05-16-2019, 12:25 AM #13
- May 2019
- 25
If the filament is curling around your nozzle then it is a sign that your z-height is too high.
08-02-2019, 06:25 AM #14
Magigoo
I agree. I have 7 3d printers from different brands and find a bit of Magigoo solves most print bed adhesion problems.
08-03-2019, 01:48 AM #15
- Jun 2019
- 7
Throwing is definitely not a good idea dear, you can go for repairing.
