Thread: Buy and build or hire and buy
05-05-2019, 09:10 PM #3
- May 2019
Thanks for the info for the CAD program. no reason I cant start relearning everything I forgot. I learned on some old version of auto cad from around 01 and I used to play around with 3d Studio Max.
Designing the center vent and duct should be easy enough they are just basic shapes and something good to start with. I have the dash and the vents that are going into the vent housing that I can use for measurements. and I can use card stock and wire to make a rough prototype with a working door so I can get the basic angles for the lever down.
and thank you for the info on materials and idea of farming out the end result. that is the part that I am afraid is going to be the biggest learning curve not necessarily what material to use but how to print it right and what modifications I would or might need to make to my printer to have a good end result.
the A/C contols are
