03-24-2019, 12:36 AM #1
- Feb 2016
- 68
Cocoon Create Profile for Cura V4
With the new Cura V4 where do I get the Cocoon Create Profile from? WinPlus only has Cura V2 Profile.I have tried coping from old Cura but it did not work properly.
It did not go to the home position but started printing where the head was. Maybe that is how V4 works? Anyone answer that question?
EDIT: Looks like it is suppose to go Home at the start of the print.Last edited by Firepower; 03-27-2019 at 09:06 PM.
03-27-2019, 08:38 AM #2
- Feb 2016
- 68
I installed the Cocoon Create Cura V2 Profile and all seems good except when the print starts it prints where the head is and does not go to Home then to the middle.
Anyone help with this?
03-27-2019, 09:10 PM #3
- Feb 2016
- 68
Looks like I need a GCODE Start that goes home.
This is my START GCODE but it does not go home even though it says G28 Z0 ;home Z.
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M107 ;start with the fan off
G28 Z0 ;home Z
G1 Z15.0 F840
G92 E0 ;zero the extruded length
G1 F200 E3 ;extrude 3mm of feed stock
G92 E0 ;zero the extruded length again
G1 F840
;Put printing message on LCD screen
M117 Printing...
Anyone list their Start GCODE so I can use or modify?
EDIT: I have it working now.Last edited by Firepower; 03-28-2019 at 11:04 AM.
