Results 1 to 10 of 14
Thread: Looking for pet-g settings
03-27-2019, 03:27 PM #6
I tend to use max of 70mm/s movement speed. or match the print speed, cuts down on a lot of the little spikes you get from sudden acceleration.
I also never cross the model when printing, cuts down on cobwebs.
I like to print actual things.
starting height=smoosh factor I presume.
ie: how much you push the filament into the bed for the first layer.
okay I'll drop that a wee bit.
Currently just printing a tiny mould wthout hinges, handle etc.
So rectangle with void.
I can check everything I need from that and also tell if the mould will be smooth enough form use.
It's 1.8 grams. :-)
try firefox - should fix your formatting and also is faster and more reliable than chrome in general.
Chrome is a pretty lousy browser, being almost a full android implementation (but without the ability to run android apps - which would be useful). It takes up a lot of space, resources and is amazing at picking up viruses.
One of the first things i do on seeing any new clients computer is to remove chrome - if it's there.Last edited by curious aardvark; 03-27-2019 at 03:33 PM.
