Results 1 to 8 of 8
03-26-2019, 09:56 AM #1
- Mar 2019
TPU Prototype needed Size - 6.5 inches tall x 9 inches wide
I have a prototype that I need printed with TPU material. I can provide .pdf and .stp file but files are too large to attach on forum. Please see attached screen shot. Can someone provide quote and timeframe to complete? Thanks!
04-01-2019, 09:44 AM #2
got a diameter and a height ? Preferably in millimetres.
also - what's an '.stp' file ?
04-01-2019, 11:54 AM #3
- Mar 2019
I have found a solution, thanks for your inquiry.
04-01-2019, 01:49 PM #4
STEP is a generic CAD output file from most CAD systems dealing with geometry.
These files maintain the exact intelligence of the structure.
Most applications that can import STEP [.stp] can export STL.
Good you found an answer SS...
I can't for the life of me read the data from the tiny postage stamp image allowed in these forums for newcomers.
...Looking real hard I can kinda see a 9" diameter and 1/8" walls. I'm gonna have to find a way to print flexibles with my printers
Good luck with your project!
04-01-2019, 02:24 PM #5
flexibles are pretty straightforward.
What printers do you have ?
04-01-2019, 02:51 PM #6
3D Systems Cube3 and CubePro. CubePro requires a special extruder setup [0.5mm v. 0.35 non-replaceable] and flexibles have never been offered for Cube3... but its been done.
04-02-2019, 01:57 PM #7
I use a 0.5 mm nozzle for most things.
Must be a way to use non-propriatary filament in at least one of them.
Start with flexible pla. slightly more rigid and much easier to use than the polyurethane based 'rubber' filaments.
Just as tough, but lacks the elasticity.
My current favourite is sienoc flexible pla - good stuff !
04-02-2019, 02:17 PM #8
New member with print issue
