03-12-2019, 01:52 PM #3
All mine work :-)
flashforge creator, klic-n-print, he3d k200, monoprice mini delta.
And a dirt cheap ctc i3 that will work once I've modded it.
To be fair the ctc was bought specifically to mod on the cheap.
The other 4 have never given me any problems that weren't my fault.
All 4 are running factory spec electronics and firmware.
If it's not broke - don't mess with it.
Getting the right print surface is a major thing.
I like printbite and dimafix.
Also got some magigoo I've yet to test, but heard good things about it
Maybe you're paying too much ?
No printer - well my mini delta did - will work perfectly out of the box.
You need to work with it's quirks.
I will say that the right slicer is a huge part of getting good prints.
For my replicator clones i use flashforge's Flashprint. For the others simplify3d - it IS worth the money.
Between the right print surface, good slicer and getting the bed properly level - that's 90% of the 'trick' to getting any printer to work well. The ther 10% is getting the print temps right for any given filament and print speed.
You've either been unlucky or you're using dodgy filament and the wrong settings.
Try one of these:
