Results 31 to 40 of 41
02-11-2019, 12:56 PM #31
I do not know was only making a statement, Have you tried to print a temperature tower.
Do not like the one I selected More here
Your temperature settings look to be the same as what is being used in my 3DP11/12 though all 3D Printers do not Print using the exact same temperatures.
02-12-2019, 11:14 AM #32
- Dec 2018
- Sweden
- 22
I printed the tower but it didn't finish.
Thefirst layer looks great now.
02-13-2019, 06:44 AM #33
It is OK.
That it did not finish you got good results you may want to search and print a new tower with higher printer temps.
02-13-2019, 12:55 PM #34
- Dec 2018
- Sweden
- 22
Well here it is, looks like 205C and higher gave good results.
02-13-2019, 06:40 PM #35
Excellent!!!
Any other Questions.
02-14-2019, 09:22 AM #36
- Dec 2018
- Sweden
- 22
Well i tried to print a tension fix twise (https://www.thingiverse.com/thing:3066664) but it came out like this.
What am i doing wrong the heat tower went well. Why won't these.
02-16-2019, 09:40 AM #37
- Feb 2019
Wat temp was this printed at? Based on your heat tower, 215-220 seems to be your sweet spot (maybe a tad higher) - at least for that filament. Have you tried a different roll of filament? I print some PLA filament at 215 and some as high as 230 on my Ender 3, depending on brand. The last pic you posted looks like a cold print to me. Is the nozzle hitting the print?
02-16-2019, 01:01 PM #38
02-19-2019, 12:36 PM #39
- Dec 2018
- Sweden
- 22
After i changed my temperature to 225C (Thanks BigDenver for pointing that out).
My prints became like this.
How come different temperatures are needed for different filament, when the temperature for the filament is on the spool?
However THANK YOU SO MUCH Roberts_clif for sticking around and helping me .
02-20-2019, 06:02 AM #40
the tempareture on the spool is usually given as quite a large spread.
usually 200 -240 for pla.
I have never bought a spool of pla that goes as low as 180-190.
So why people try and print pla at these temperatures, I have no idea.
225 is high, I usually use somewhere between 200-220.
And yes the colour and brand of pla make a lot of difference.
I find that black pla prints well at the lowest temp. White and coloured pla tend to print at higher temps.
It also depends on how your printer works. Direct drive will get away with lower temps than bowden systems.
Also the quality of your heater and the ability of the thermistor and board to keep the temp stable will make a difference.
There is currently NO standardisation for 3d printer filaments.
Different producers use different additives and don't have any legal requirement to declare them.
I'm not colour focussed, so I tedn to use whatever make and colour filament gives me best results - spray paint is cheaper than filament if people want to change the colour.
Hands down the best filament I've ever used if flashforge's red.
It's a semi-translucent filament, but just fabulous to work with and seriously tough.
Printed a little plastic key for paper towel holders recently. just a flat piece of plastic with a cutout. 1.5mm thick.
The flashforge red priunted it out bang on specification.
As the original was white I switched to esun white filament.
Kept all the settinsg the same and used the same stl.
The white ones are between 0.1 and 0.3 mm thicker than the red one.
I have no idea why.
3d printing is currently as much an art as a science. Until we get some kind of legislation to standardise filament manaufactur, that's how it's going to stay.
