Results 1 to 9 of 9
Thread: print moving upward as printed
02-11-2019, 10:42 AM #9
- Jan 2019
- 8
What does z steps do? Does distance increase or decrease with higher number? Only getting 3mm movement out of z axis when control panel says I moved 10mm. Changed settings to 800 ,then to 80 no difference. Here is the default settings in the config file.
>XAXIS_STEPS_PER_MM 80 #X steps per mm
>YAXIS_STEPS_PER_MM 80 #Y steps per mm
>ZAXIS_STEPS_PER_MM 400 #Z steps per mm
>EXT0_STEPS_PER_MM 90 #E0 steps per mm
New member with print issue
