11-23-2018, 10:25 AM #1
- Nov 2018
Smart Extruder + Explosion now it is encased in filament
This extruder is only a couple months old. Thankfully I have a backup extruder. Do you think Makerbot will replace it?
11-23-2018, 02:14 PM #2
Makerbot most likely will not replace. They however will sell you another.
I would heat up the hot end as if I was going to print and remove the largest globs, using side cutters and needle nose pliers.
After the majority is removed then depending on what filament you were printing would determine how I would proceed in cleaning the remaining filament
If ABS I would use a jar or acetone and de-solve the remaining filament.
If PLA I would slowly heat and scrape the filament from the parts until I had the more expensive retrievable parts.
Then determine if it was worth my time to spend on the cheaper parts if not then throw the cheaper consumables away, and replace with new.
Consumables
Thermister
Hot-End Heater
Nozzle
Hot-End Heater BlockLast edited by Roberts_Clif; 11-25-2018 at 06:12 AM.
01-15-2019, 02:32 AM #3
what happens? how can it block? you can ask makerbot for help.
01-24-2019, 09:12 AM #4
'ask makerbot for help '
Now that's funny :-)
heat and remove, should come off easily enough.
But for it to do that - it must have come out somewhere other than the nozzle.
So you might need a new extruder.
01-25-2019, 03:04 PM #5
- Dec 2018
I had the exact same problem in November, too. I am having trouble finding a vendor for the Smart Extruder +. Have you had any success?
01-25-2019, 03:06 PM #6
- Dec 2018
Do you know where I can find replacement pieces for the Hot End and pices mentioned? Mine is the Smart Extruder +
01-25-2019, 03:08 PM #7
- Dec 2018
Were you able to find replacement parts? I have problems too. I need Hot end parts for the Smart Extruder +
New member with print issue
