  1. #1
    I need a good coating for all-around use. High-build polyurethane?
    I have searched the forum, and didn't find too many recommendations besides XTC-3D.
    Polyurethane seems like the best thing for me. However, the regular stuff is too thin. After 2 coats, it did not really fill in the crevices. It seems to reduce as it dries and also scratches off.
    I asked at the hardware store about a thicker polyurethane and was told to get High-build. It only seems to be available in $35 cans, so I wanted some opinions.
    I do not like the idea of an epoxy coating that has to be brushed on.
    Here are the uses I want it for:
    • Can be applied by dipping. Doesn't need to be brushed on. This is so I can coat interior spaces like tubes or bottles.
    • fills in layer crevices, preferably with one coat.
    • waterproofs surface
    • food safe
    If anyone knows about some good products that I haven't mentioned, please post them. Also please post any knowledge you have about high-build polyurethane.
  2. #2
    Engineer ralphzoontjens's Avatar
    Nov 2013
    Location
    Tilburg, the Netherlands
    Follow ralphzoontjens On Twitter Add ralphzoontjens on Facebook Add ralphzoontjens on Shapeways Add ralphzoontjens on Thingiverse
    Check out Alumilite Crystal Clear Casting resin, and the Masterbond epoxies.
Tags for this Thread
