12-30-2018, 06:18 PM #1
- Sep 2018
- 7
DaVinci Pro - "settings do not apply to material" message
Brand new at this, only about a week. Started with XYZ ABS filament, no problem. Went to Amazon PLA, no problem. Switched to Hatchbox PLA and started getting this message:
Your setting does not apply to the installed material.
I've varied the settings and get the message regardless. Anyone seen this before and can narrow down the supposedly bad setting?
12-31-2018, 06:49 AM #2
check in the slicer that you've got pla selected.
Thought the davinci used propriatary filament ?
12-31-2018, 07:07 AM #3
- Sep 2018
- 7
The DaVinci uses proprietary filament and also allows for 3rd party filament, and that's where the problem was. At some point between prints, I put the proprietary filament cartridge back in the slot to store it. The printer must "see" it (there are conductors on the cartridge) even though I specified third party in the set up. Took it out and tried the print again, no problem.
01-01-2019, 09:17 AM #4
