View Poll Results: Robo R1 or Da Vinci Pro 3-in-1
- Voters
- 1. You may not vote on this poll
Robo R1
1 100.00% -
Da Vinci Pro 3-in-1
0 0%
Results 11 to 18 of 18
Thread: Robo R1 vs DaVinci Pro 3-in-1
11-28-2018, 05:37 AM #11
no idea - might do, guess it would depend on how much pressure was used to apply the transfer.
11-28-2018, 08:33 AM #12
- 885
I was intrigued to read in the notes for the mug press that the pressure to ensure a good print would require that the foam pads surrounding the mug be expanded (bulge) to the mug top and also to close the sides of the clamp. Pretty substantial forces appear to be involved.
I think it might be possible to use an epoxy coating on the 3D printed mug to strengthen and make watertight the mug, but epoxy conducts heat too, making the sublimation printing aspect yet questionable.
11-28-2018, 11:59 PM #13
- Oct 2018
- 6
Hm, sounds like this might not work if that's the case...anyone have any other suggestions?
11-29-2018, 03:32 AM #14
- 885
If your objective is to create a prototype mug, you could 3D print the model, ideally without undercuts, then use the model as the "plug" for a silicone mold. If the mug has a handle, that would complicate things, but would still be possible. Once you have the mold, you could use any quality casting resin to generate another mug that isn't so sensitive to temperature. You'd want to sand away the layer lines or otherwise treat the 3D print (primer, glossy paint) before performing the casting, as silicone molding picks up every detail, even fingerprints! It adds another series of steps to the process, but you've referenced it as a prototype, not a production, justifying the extra work.
11-29-2018, 10:22 AM #15
first - try it :-)
People keep telling me I can't do things with fdm.
Mostly they're wrong.
So first thing - try it, might work, might not. You don't know till you try :-)
11-29-2018, 10:49 AM #16
- 885
I like to make mistakes too. It's better if the mistakes could be small but the learning experience will be large. It's even better if the mistakes aren't repeated, but as time passes, it's easier to forget the learning process.
08-24-2021, 11:35 AM #17
- Aug 2021
08-24-2021, 11:46 AM #18
- 885
Others might wonder as I do, why Quinny speaks of himself/herself in the third person. (grin)
