Thread: New Fillament, New problems
11-25-2018, 10:37 AM #2
The model appears to be under extruded.
Here is one I printed.
What I determined was I had mistakenly set Cura Slicer to a filament diameter of 3mm in and should have been set to 1.75mm
This caused my Under Extrusion.
I have had the Throat tube Teflon tube deform causing the same filament under extrusion Shown below.
These Brass nozzles are plugged with the deformed Teflon tubing. There should be nothing but a brass nozzle.Last edited by Roberts_Clif; 11-27-2018 at 11:13 AM.
