Results 1 to 9 of 9
04-12-2014, 11:30 AM #1
Hyrel Sample Prints: Davo's Three Resolution Test Print
I designed a new test print last week. The bottom (longest) section is printed with 400 micron layers; the middle section with 200 micron layers, and the top section has 100 micron layers. Each section is 4mm thick.
Here are some pics of it:
http://samanna.net/3dpb/400.200.100.overall.png
http://samanna.net/3dpb/400.200.100.bump_side.png
http://samanna.net/3dpb/400.200.100.angle_side.png
05-06-2014, 01:02 PM #2
Over 300 views, no comments... can you folks see the images?
05-25-2014, 02:19 AM #3
I can see them just fine. Very nice quality and it has a didactic value in itself.
08-27-2014, 06:23 AM #4
yep definitely looks like a block of plastic printed at different layer resolutions :-)
the bump side does look kinda rough, particularly for the .1mm top print.
what material were you using ?
09-01-2014, 05:32 AM #5
- 349
And what slicer can do this?
09-01-2014, 06:12 AM #6
any slicer can do that - if you print one file after another. Would be pretty easy to do with makerware. But in 3 prints not one.
But I'm guessing the onboard hyrel computer has it's own propriatary slicer.
09-01-2014, 10:39 PM #7
- 349
So the separate prints must know to keep the same Z height between prints.
09-08-2014, 04:38 PM #8
- Jul 2014
- Williamsburg, VA
- 6
Looks good, I hope my printer ships this month ...
09-09-2014, 06:26 AM #9
We use the standard current version of Slic3r.
I generated three gcode files, then combined header1, body1, body2, body3, and footer3 into one file.
