Results 41 to 50 of 50
Thread: The curse of ABS (Warping)
12-04-2013, 09:23 AM #41
- Nov 2013
- Gedser, Denmark
well. I have no problems with ABS. But I have used many figurations until I did this one:
Hotend 270 degree C
Bed 115 C
Filament speed 292
Infill 0.15 - 0.3
Everything works like a charme. My 3D printer is a RepRapPro Mono Mendel. with Melzi board.
Regards
Torben
02-16-2014, 08:41 PM #42
- Feb 2014
- Chicago
- 14
Keith-
The Elmer's glue solution I am aware of is using an Elmer's glue STICK. This is not quite the same as liquid glue as it is paste-like substance. It comes in tubes like lipstick and is used in a similar way on your build plate. You 'write' it on the build plate. I think the European equivalents may be Pritt or UHU that make glue sticks. These are available at office supply stores.
Good luck and cheers!
03-12-2014, 08:41 PM #43
04-08-2014, 04:56 PM #44
- Feb 2014
- 51
Yeah, using Elmer's Glue Stick is much easier than applying liquid glue. I also find that Elmer's is much more consistent and smoothly applied than the UHU brand. I haven't tried Pritt though...
04-08-2014, 05:51 PM #45
Well i find hairspray good enough on most prints these days,
On sharp corners i normaly use a Brim feature, Almost never failed on me, The only thing that does happen is that the layers split, but thats all realy.
I don't believe we have Elmer's glue in Europe.
04-08-2014, 07:01 PM #46
- Honolulu, HI
- 199
I use aquanet on kapton and a heated bed at 85C. Works most of the time. When I do get warping it seems to be related to bed leveling more than the surface.
04-11-2014, 03:16 PM #47
04-11-2014, 05:00 PM #48
- Apr 2014
i3 here with a J-Head Mk v. Lots of warping of larger parts (Wades extruder, or the X-carriage) until:
Kapton, 105 degrees. Make sure the whole bed has heated evenly so leave for 15 mins after it has reached temp.
ABS at 235 degrees
No fans, draughts, door closed!
ABS paste on the kapton. Until I applied the paste I failed.
Now it's all working!
I still get minor layers peeling from each other occasionally.
04-12-2014, 05:58 AM #49
- Mar 2014
- Vienna
- 47
Over a couple of weeks I found out that prtinting in ABS is quite tricky for me and I never had perfect results so far. Happy to hear about all your experiences here, but I´m asking myself what would be a real guideline of dos and don´ts? for instance in terms of bed temperature we have quite different results here...
Let´s try to summerize this thread:
- heat bed temperture between 105 - 120 degrees, after first layer reduced to 80 - 100 degrees
- print on Kapton, PET tape, aluminium, glass or mirror - so it don`t matter?
- prepare the bed with glue, ABS paste, glue stick
- use more infill
- constant high ambient temperature or better: heated chamber
- no fan´s at all, problematic if your hotend needs one
Did I missed anything?Last edited by ciutateivissa; 04-12-2014 at 06:03 AM.
04-12-2014, 07:30 AM #50
Thanks to all of you for these contributions., just a few questions.
@RP Iron Man : nice trick with the garbage bag, how hot does it reach inside ? Don't you fear to overheat some components ? Or do you make holes to keep warm but not too hot ?
I was looking at the Printrbot Go v2 and they wrote on their twitter page they wound't do a heated bed due to warping. So I guess from what you all put this is mainly due to the very "open architecture" and could be solved with closing it a bit, that so ?
Anyone using a Creatr Xl or such big volume machine ? Do they have the same issue ?
Today, 02:07 PM in General 3D Printing Discussion
