11-04-2018, 12:03 PM #1
- Nov 2018
PA12 HP MuliJet Fusion ( nylon polyamid ) bonding
Hello,
I'm designing a Rapala lure prototype ( 17cm long ) and I need to stick together two half parts of it but I'm wondering which glue to use
the wall tickness is thin ( around 1.75mm ) even if there are larger bonding area ( the head and the tail ) so my fear would be a melting and the strengh of the bonding too even if for that I'm going to use an additional system by using a special shrink tube who shrink immediately with boiling water
Thanks by advance
11-05-2018, 06:05 AM #2
if you're using a hp multijet, why not just make it in one piece with holes for the hooks and hook wire.
probably going to be esier than trying to find a glue to stick nylon.
11-05-2018, 06:40 AM #3
- Nov 2018
I can't as I use tungsten wheight inside
Maybe I could ask to the printer to add them inside but it is online stuff so I don't think they will be enjoyed to do this ...
11-05-2018, 06:50 AM #4
pretty sure you can't open a multijet fusion machine during printing.
Use tungsten shot and fill the hole after adding weight.
Given what happens to a lure, glueing it is just asking for trouble.
New member with print issue
