Results 1 to 10 of 12
Thread: Can Eny Help me out a drawing
09-25-2018, 01:23 PM #1
- Sep 2018
- 6
CAn eny here help me out make a drawing of this so i can print it out its a gasket in hard plastic the cirkle its about 100mm its not wery good drawing but i hope some can understand and help a Dummy norwegian out here AT least giwe me answer were to get help i can pay for this help
09-25-2018, 03:47 PM #2
- 892
If you can refine your drawing to present the information in a more-standardized manner, it is an easy matter to create a 3D printable file.
The image above is a file created using OpenSCAD with a test profile similar to your drawing. I did not use any specific dimensions, as there are too many questions in your drawing.
Is the radius of the curve centered on the vertical and horizontal lines of the radiused section? If not, where is the center of the radius? If the curve is not a critical dimension, make note to that effect.
The inner lip appears to be 1.37 mm thick, but does it have a sloped inner edge? My image did not present that profile. What do the 3.5 mm and 4.5 mm dimensions represent? It appears that you require the overall height to be 2.3 mm. Can you confirm this is correct? The 103 mm dimension applies to the outside diameter of the overall part?
If you could improve your drawing, it would make things much easier.
09-25-2018, 04:02 PM #3
- Sep 2018
- 6
WOw meny thks You are amazing
The inner lip appears to be 1.37 mm thick. This is the outer part of the lip. The lip should turn out and have a slight slant, but does it have a sloping inner edge? My picture did not show the profile. 4.5 mm is the total width of lip What represents 3.5 mm is the quarter circle lip is 1.37mm thick overall height is 2.30mm and 4.5mm dimensions? It seems that you need a total height of 2.3 mm. Can you confirm that this is correct? The size of 101 mm applies to the outer diameter include the lip
09-25-2018, 04:27 PM #4
- 892
What are dimensions: A, B, C ?
More questions to follow.
09-25-2018, 04:33 PM #5
- 892
What are dimensions: D, E, F ?
I understand that the center of this circle is to the left, while my first model has the center to the right.
09-25-2018, 04:49 PM #6
- Sep 2018
- 6
F 1.37 mm E 1.5mm D1.0mm
09-25-2018, 04:51 PM #7
- Sep 2018
- 6
A3,5mm B 2,30mm B about 5,5 mm
09-25-2018, 05:15 PM #8
- 892
Please note that A plus E = 5.0, while in the drawing C = 5.5 and should be the same as A plus E.
Please let me know which numbers to change to make it correct.
09-25-2018, 07:17 PM #9
- 892
Here's an updated drawing, using 5.0 as the total width, which can be easily adjusted if needed. This drawing is to scale, which shows you how the proportions will appear in cross section.
Let me know if this is correct and acceptable, and if you require any changes. Please consider how any change you request will affect other dimensions. As an example, if you require 5.5 mm across the bottom, which other dimensions will be changed and by how much?
09-25-2018, 07:55 PM #10
- Sep 2018
- 6
nothing allok now
Ender 3v2 poor printing quality
10-28-2024, 09:08 AM in Tips, Tricks and Tech Help
