I saw that too, but I suspect that it would require a more porous material to be useful. The Plastidip will peel with enough force, but that can be mitigated by having it wrap around the ears a bit. Thorough cleaning of the surface will improve the adhesion, of course. Even ordinary rubbing alcohol is likely to be good, as will window cleaner.
