Results 11 to 14 of 14
09-14-2018, 06:33 AM #11
- Sep 2018
- 6
I found SLS printing guide, it says all holes should be larger than 1.5 mm diameter. My minimal size is a 2.5mm, maybe I will change it to 3mm, but what I am trying to figure out, is a hole and pin size compatibility, mostly I need free rotation and cylindrical sliding. For example, if I have hole 3.2mm, my pin is 3mm, but I'm not sure, if it is not too little or not too much, how nylon behaves in this caseLast edited by lado; 09-14-2018 at 09:58 AM.
09-14-2018, 07:30 AM #12
- 885
3.2 to 3.0 millimeter is 200 microns and that's very close fit. I think a fair approach would be to ask the service provider for a reference figure.
09-14-2018, 08:49 AM #13
pet-g would work as would ninjateks armadillo. I've m
Made gears with 12 teeth, 1mm thick and 8 mm diameter. That was from pet-g - couldn't bend or break them just using my fingers.
And those were the large gears for that particular project :-)
Don't see any reason at all you can't make this yourself. Without pictures I have absolutely no clue what you are actually making :-)
But glass filled nylon is both strong, stiff and durable.
09-14-2018, 12:28 PM #14
- 885
Curious, what printer have you used to make these tiny items? It now pops into my alleged mind that lado could have inexpensive success using a printer with a smaller than "standard" nozzle. A genuine Prusa with a 0.2 nozzle might give strong tiny features with nylon or petg and save a bundle of money.
