08-14-2018, 08:38 AM #1
- Aug 2018
Is it possible to print in multicolor with SLA?
Hey there. I?m new to this forum and also new to 3d printing. I?m working on a projekt, a special knob for a potentiometer. The top 1mm has to be in white and the rest of it (12mm) has to be in black. If already printed it with a FDM printer but I need a better resolution. So my question is:
Is there a company which is doing multicolor sla jobs? If yes I am very thankful for your help. Because I?m based in Austria european companies are preferred!
Thanks, mike
08-14-2018, 10:54 AM #2
nope.
the best you could do would be to print the black or white part.
remove, cure it, replace the resin and then finish with the other colour.
As far as I know there are currently NO multicolour sla resin machines around. The resins would mix and the colours blend.
But you could get it printed on one of the multijet machines. powder and resins.
08-23-2018, 10:09 AM #3
- Aug 2018
- 19
I'm not sure if this is what
curious aardvark was saying, but couldn't you print the white part and the black part separately and glue them together?
