Thread: 3D modeling problems
03-29-2018, 07:59 AM #1
- Jan 2018
Hello,
1. What tool should I use? The Civ 5 files are Granny .gr2 files while Civ 4 units seem to have been made using .nif file type. What program is capable of handling the 3D files.
I tried getting myself 3DS Max 9 but I failed in my attempts to activate it, I could not get a working code from the keygen, very hush hush, we don´t want to advertise piracy here do we?
Anyway there is no way in hell I´m gonna be able to afford a legit copy of 3DS Max which costs over a thousand dollars, only corporations can spend such amounts on software, no way.
So I decided to get a free program instead, I downloaded Blender which is free and is supposed to be a really good program, but alas I have been unable to open any of the Civ 5 or Civ 4 files with it. It appears I need some sort of conversion scripts to import .nif files to Blender and so far I have been unable to get any scripts to work.
Civ 5 files are another problem, they are Granny files to which I have no knowledge if there is a conversion script even available for Blender.
The question is: How do I get the #D files to open up in Blender?
Please help
I didn't find the right solution from the internet.
References:
https://forums.2k.com/showthread.php...eling-problems
Digital production company
Thanks
07-02-2018, 07:16 AM #2
- Oct 2016
- 10
Well, there are plugin for Blender to import and export .nif files.Unfortunatelly I'm unable to find any .gr2 plugins.
07-02-2018, 11:29 AM #3
You can try to convert .gr2 to .obj and then export it to Blender for example
07-09-2018, 06:21 AM #4
- Oct 2016
- 10
And can you recommend any good converter for this?
07-09-2018, 11:05 AM #5
09-15-2018, 05:50 AM #6
