Thread: .stl won't slice properly
06-13-2018, 10:49 PM #1
- Jun 2018
Not sure if this is where to put this, (just joined), but I need the answer urgently for school. I made a model in blender that I exported as an .stl file. Everything seemed to be going fine, until I sliced it. It didn't do anything; no error message, except the popup that it was successfully sliced. (Same result in both Slic3r and Printrun). Everything worked but there was nothing there anymore; if I did it in .obj, it was successfully previewed, but the same result when slicing. No error message, successfully sliced; nothing there. Please answer quickly, this is due in two days aaaah ;-; !!
06-14-2018, 04:49 AM #2
- 886
consider to run the model through an online checker program, or use Meshmixer as a stand-alone with the Analyze feature.
You could also attach the file here for others to examine in a similar manner.
06-14-2018, 08:01 PM #3
- Jun 2018
The online checker problem has the same problem as the slicers, it doesn't detect any problems, no error msgs, but there's nothing there.
06-14-2018, 10:12 PM #4
- Jun 2018
resolved! after 2 freaking hours of troubleshooting, thx anyway
06-15-2018, 04:16 AM #5
- 886
what was the final solution?
12-04-2018, 05:57 AM #6
was it an ascii versus bin stl file type issue ?
I've had that. Think you need bin for most slicers.
09-22-2019, 09:55 AM #7
- Sep 2019
New member with print issue
