Thread: Temp setting on PC vs Printer
06-07-2018, 06:01 PM #1
I'm new to 3D printing, in CURA it lets me select the nozzle temp say 200, on my CR10 it also has a temp setting, i wold assume it sets my printer to what i set in CURA?
06-11-2018, 06:40 AM #2
usually the temperature for printing is set by the gcode.
Temperature settings on the printer are mainly for changing filament. Well that's all i've ever used them for.
06-11-2018, 07:42 AM #3
I use the Printer temp to set as preheat, while preparing the model. Ready to Print start with a preheat.
Slice part sent to printer, start print from this preheated state. Can be used to change current color filament.
06-13-2018, 06:21 AM #4
true, if I'm doing a pre-heat. I usually do it via the simplify3d control panel.
06-10-2019, 12:36 PM #5
- Jun 2019
Simplify3d is great for this work.
