Thread: 1st Layer
04-19-2018, 11:23 AM #1
- Mar 2018
- Murphy, Mo
- 10
1st Layer
This is all new to me, using Cura 3.2.1, when the 1st layer is finished printing I can read the logo on the bet mat through the 1st layer. That would indicate to me that the ribbons of filament are not touching. Is this correct?
Slicer: Cura 3.2.1
PowerSpec Wahao Duplicator i3D Plus
04-19-2018, 12:59 PM #2
depends how thick the first layer is and what filament you used.
But generally first layers - being really thin - are somewhat transparent.
04-19-2018, 02:20 PM #3
- Mar 2018
- Murphy, Mo
- 10
1st layer line width is 0.4 +125%
filament: 1.75mm
Color: black
Inital layer height: 0.3
04-20-2018, 06:47 AM #4
so yeah, you should be able to see through the first layer.
Don't understand the line width. so is it set for 0.5 ? or 0.9 ?
And did you actually measure the extruded filament diameter - or just guess ? :-)
04-20-2018, 11:09 PM #5
- Mar 2018
- Murphy, Mo
- 10
Line width ends up being .5
I measure it but I didn't not take all the measurements and average them. As I remember the measurement ranged from 1.75 to 1.76 taken along 2 meters and at 90 degree angles
04-21-2018, 07:12 AM #6
that's fine - I have never bothered measuring actual filament diameter.
It's one for those things that harks back a few years. Even the real cheap modern filament is dimensionally accurate.
You do need to know extruded filament diameter - as that's used by the slicer to calculate just about everything else.
04-21-2018, 08:32 PM #7
- Mar 2018
- Murphy, Mo
- 10
I have never thought about measuring the extruded filament. That is a good idea.
