02-27-2018, 10:28 AM #1
- Jan 2018
How to control the print direction of each layer individually?
Is it possible to, for example, make each layer of a solid cube offset by a certain angle? Or maybe alternate layers between concentric squares and normal lines.
03-01-2018, 01:49 PM #2
- Jan 2018
Nevermind, I guess the beta version of Cura for sigma bcn doesn't let you change the infill pattern. Is there a way to modify the gcode somehow as a workaround?
03-06-2018, 06:16 PM #3
- Jul 2017
- 184
I'm not too sure what you mean by changing infill direction. From what I'm aware the rectilinear/grid infills alternate direction to give you a cross hatch sort of effect. Secondly, "modifying" the Gcode itself for a different infill would be a living nightmare. You'd need to program each and every move it makes. I doubt you can't change infill settings, but even if that's the case just use a slicer where you can.
03-07-2018, 09:14 AM #4
03-07-2018, 10:44 AM #5
Sounds also like Grasshopper. There is a plugin that lets you modify the GCode - Silkworm.
Printare 3D Bucuresti
Any sufficiently advanced technology is indistinguishable from magic. Arthur C. Clarke
New member with print issue
