Results 1 to 10 of 15
12-12-2017, 12:57 PM #9
- Nov 2017
- Earth
- 9
Thanks guys. Roxy, after your input, I was able to lay it down (I know that can also be done in the slicer and that's not a big deal to do). I thought that was going to be how it was done, but after trying it, I couldn't get it right initially, but with some trial and error and your input, I finally got it.
I'm guessing OpenSCAD is only command line? No drag and drop objects and then drag it to the shape you want (or select it and enter the dimensions you want)? If so, that'll make for quite the learning curve. From the perspective of navigating around your model, OpenSCAD is GREAT and is they way they all should be - very intuitive. The actual building of items from a command line is a bit daunting (IMO). Some kind of a blend of both would be ideal in my opinion - drag and drop objects, pull, squish and merge objects until they're roughly what you want, then be able to enter more exact dimensions. Or maybe I'm just crazy .
Trakyan, I'll take a look at Solvespace too.
