10-23-2017, 10:11 AM #1
- Jul 2017
- 8
Under extrusion or layer separation
I need some help with this one as I have tried multiple settings and cant get this one figured out. Attached is a phone where the layers "look" to be spearating in some spots. I cannot tell if this is from under extrusion or cooling or what. I have tried turning the temp up to 210C. I have tried turning the heat bed up to keep material warmer (70C) I have set the extrusion to 105% I have decreased the cooling fan speed to 80% The material is Craft PLA Filament with 195-215 recommended temp. I have not gone to 215 yet.
Any advise would be greatly appreciated. I do not have this issue with my Hatchbox PLA so it might just be the material but I cannot find this color material from another vendor.
https://www.dropbox.com/s/lq04gs42qb...20AM.jpeg?dl=0
10-23-2017, 03:02 PM #2
what speed are you printing at ?
Different make filaments behave quite differently.
I'd say you need to print this slower - and the colour is white.
How can you not find it anywhere else ?
Oh yeah extrusion should be 100%, temp 210, speed - slower than you are currently using :-)
10-24-2017, 05:43 AM #3
- Jul 2017
- 8
I am currently printing at 40mm/s I will try slowing it down and see what happens. The color may look white in the photo but its not, its actually light gray, I can find lots of regular gray from other manufacturers and found one that claims light gray but when I got it in it is not as "light" as this one.
