Results 1 to 10 of 74
10-01-2017, 04:46 PM #27
- Aug 2017
- 95
I've done it a couple of ways. I watched a youtube video and this guy said to spray a few heavy layers on and let it dry. That worked well, but I have fastened my glass to the bed and don't really want to be spraying inside the machine. So I came up with an alternate method to just spray a paper towel good and wet and apply by wiping to a preheated bed, like 60 degrees. Spray, wipe and repeat a couple of times. It dries pretty much instantly and you are ready to go. It seems to work well with most materials but best with ABS. When the bed cools the ABS part is totally unstuck. Amazing. PLA seems to stay stuck a bit even when it cools so sometimes takes some work to release.
Edit: I don't really know how often to refresh the Aquanet or clean and reapply since I am pretty much printing on my original application after a couple dozen models.
