Results 1 to 10 of 60
Thread: Choosing my first Delta Printer
09-23-2017, 01:29 AM #35
- Jul 2017
- 100
I got my Ezbed and the limit switch needed. 30 minutes of me noob trying to solder the wires xD, and then putting the bracket and the program... Wow.... It's not perfect, and I feel Like I may have found the reason why. The Bltouch bracket cause I haven't removed it yet, I found that at a certain point when the EZbed was working, the rod was slightly bumping into the mount, it wasn't enough to cause a huge sound, but I was very close to it at the time, and I noticed it, I wonder if that is the reason why that I was getting such a huge jump in the level numbers (when I was using the BLtouch).
Nevertheless, just.... wow... I need to remove the BLtouch mount and do it again, but... less than 1 hour of work and leveling all together... I am speechless...
It looks like the point in the bottom right of the pictures the nozzle is just slightly squishing the PLA? not too sure though, but my god at least it sticks now, more testing needed, but yes for those who are seriously having trouble leveling this, I strongly suggest Ezbed, as I've said, if you look through my post, I've spent over 40+ hours just trying to MANUAL level it and then BLtouch programming, and then this just works. Granted, I can't change the encoder settings, but by golly. Yes I'm repeating so much but I am just so happy right now (fingers crossed).
again, are those parts where the nozzle is too close and overextrusion? can't really tell...
https://www.dropbox.com/s/2h6vs36ggri8ak7/2017-09-22%2023.25.16.jpg?dl=0
https://www.dropbox.com/s/59dmzsigzh...25.41.jpg?dl=0
https://www.dropbox.com/s/6zvjzwjt46...25.34.jpg?dl=0
