Thread: New 400x400x300 Printer
09-18-2017, 07:03 AM #1
- Apr 2016
- 12
Hi
Just finished building my new printer.
Its seams ok when testing and adjusting single axels, but when working all together it starts to fai some random motor,
I'm using a total of 8 nema motors:
4 on Z axel
2 on y axel
1 on x axel
1 for extruder
Heated bed uses 220v with a SSR
Extruder uses a separeted 12v power supy wtih a SSR
I'm using a 12V 20A power suply, but for the sinthoms it seams that i'm low on power.
Can i get your feedback?
10-08-2017, 11:51 AM #2
well given that my 350mm heatpad will drawer 27 amps.
As you'v got a 400mm x 400 plate. I'd say yes, not enough power.
Also nema 17 moptors draw around 1.7 amps. So 8x1.7 is only 13.6
(reads post again) is the heat pad attached directly to the mains or via the main psu ?
Have a look at led lighting power supplies.
I got a 600watt 50 amp one for £15 :-)
Same units but much cheaper if they think you're fitting led lighting rather than building a 3d printer
10-09-2017, 08:31 AM #3
Also... with 4 motors on the Z-Axis, how are you driving them? Most stepper motor driver chips can't even power a single motor at full power. With 4 of them the Z-Axis would be very weak if all powered by the same chip.
10-16-2017, 08:40 AM #4
- Apr 2016
- 12
10-16-2017, 08:42 AM #5
- Apr 2016
- 12
Changed power supply with 50A, and it worked fine until Rumba stopped talking with pc
12-26-2017, 10:06 AM #6
- Apr 2016
- 12
Finally it's done.
To duplicate the ports of z and y motor used DuoWeiSi expansion boards made simple Y cables to get enable, diretion, step and 5 volts from rumba, and seperate power suply for these motors.
https://pt.aliexpress.com/item/DuoWe...311.0.0.fTJhdZ
e4477ac4-6319-489b-9326-8cc6da4b8f21.jpgNow waiting for Mk10 extruder parts to upgrade for dual extrusion.
Here are link if you want to download Sketchup files:
https://3dwarehouse.sketchup.com/mod...r-400400-Vslot
Printer design
https://3dwarehouse.sketchup.com/mod...inter-extruder
Printer heads design
