Results 11 to 13 of 13
09-09-2017, 09:14 PM #11
- Sep 2017
- 12
Mostly via USB cable, though I did try the card. If anything it seemed better with the SD card. Now I've gotten it to stop clogging, but the print quality is not good. I'm wondering if I need to change the sheet on the print bed. It's still the original one from a month or so ago. I have about 72 hours worth of printing in that time.
09-10-2017, 06:31 AM #12
- Sep 2017
- 12
I'll try that, thanks a bunch for all of your help. I'm a noob at the 3D printing stuff and this forum is saving me tons of trial and error.
05-17-2018, 10:21 AM #13
- May 2018
I am having a similar issue with the same printer, also I am brand new to printing so wanted to rebump this thread to see if there are any further suggestions.
To add to the discussion, my printer starts out fine for the first and maybe second layers, then extrusion tapers off suddenly and no further filament is extruded. I have taken apart the extruder and am not seeing any distortion to the feed as displayed by the original poster.
This problem also seems to happen quicker as I make repeated attempts which leads me to think it is heat creep related. Printing from a cold start often gives me an extra 5 minutes of printing before the extrusion stops. I have tried modifying a number of settings including extruder temp, flow, print speed, etc with no discernable improvements.
Furthermore, I have never seen my secondary fan spinning. Is there any way to test if this fan is functional? Do I need a volt meter to find out if it is getting power? I am unsure how to tell if this is a sensor problem or fan problem.
Any and all advice is much appreciated.
