Results 11 to 20 of 20
07-22-2017, 03:15 PM #11
- Apr 2017
- 36
Nepherael - well that is certainly interesting. Actually last night I did take the card out and put it back in without turning off the machine, and it worked. But the next time I get a card read error, I'll definitely try what you suggest. Thanks!
07-24-2017, 05:54 AM #12
- Jun 2016
- Oklahoma
- 904
07-24-2017, 11:23 AM #13
- Apr 2017
- 36
Well, yesterday the SD card was the least of my worries. I had my second extruder clog/filament jam since I've owned the machine, and it was my own damned fault. I added an extra process into a Simplify file at the last minute and forgot to check the defaulty temperature settings. A third of the way into the print, when it hit that process (I was printing PLA from the left extruder), the temperature for both extruders shot up to the ABS settings - the left extruder 30 degrees hotter than I wanted, the right extruder cooking while doing nothing, and the bed 50 degrees hotter.
I decided to let it run and hope for the best. About 30 to 40 minutes later, when it hit the end of that process - the left extruder essentially shut down while it had to cool 30 degrees. Guess how well that worked? Yep, you guessed. Had to tear the whole thing apart - had truble getting the left stepper motor out and ended up taking apart the right too - which meant when I put it back together, I didn't have one fan as reference - I ended up putting then on backwards. Luckily I caught that error almost instantly, because the fan sounded different.
Bit off topic, I know, but moral of the story is - always check those temp settings for both extruders! And if you do see the temps shoot up because you got settings wrong - don't hope for the best! Shut down the print instantly!
Okay, back to SD cards.....
07-24-2017, 11:37 AM #14
- Jun 2016
- Oklahoma
- 904
You can adjust temps from the printer control panel. Worth a try.
07-24-2017, 12:00 PM #15
- Apr 2017
- 36
07-24-2017, 12:42 PM #16
- Jun 2016
- Oklahoma
- 904
While it is printing push the center button or the back arrow, probably doesn't matter what you push. Then look at the menu and scroll. You should see extruder temp and bed temp and some other stuff.
I think it will over ride until the file tells it to do something different but I am not sure.
Test is out and see!
07-24-2017, 03:01 PM #17
- Apr 2017
- 36
LOL, Wirlybird - "test it out and see". I wish I had that luxury. My deadline is so desperate that if I lose hours of printing through a test I'm screwed. But if I have no choice but to change temps or cancel the print anyway - I'll give it a try.
Thanks to both you and number40fan for the feedback.
07-24-2017, 03:17 PM #18
- Jul 2017
- 42
I can verify that changing extruder and bed temp from the printer will override. If there is a command at higher layers to change it it will change again but if you know that command is coming just override it again
07-24-2017, 07:52 PM #19
- Apr 2017
- 36
Nepherael - that's what I needed to know. If I can change it manually and have the software change it back at the appropriate times, that's very helpful.
09-12-2017, 05:52 PM #20
Only time I got an SD error was when I did a "hot swap", that is I did not turn off the printer when removing/inserting the card. Once I turned it off and inserted the card, it has worked fine ever since. I don't think the Creator Pro likes hot swap. This also occured on another Creator Pro at our local library. Again, it seemed to work fine once inserted when the machine was turned off.
