Results 1 to 10 of 354
Thread: 370mm X 250mm X 300mm
05-06-2017, 08:22 PM #11
I have a lightweight titan extruder to setup and install but I still need some more pieces to make it complete. Like a volcano. So for the time, I am going to use the oem tevo extruder. But it is getting this bracket that hinges the extruder 15 degrees out..
before this modification the x axis was limited by the stepper motor on the extruder hitting the frame. This was as far as it would go before..
And with the 15 degree extruder mount the extruder can go all the way to the edge of the print bed..
front shots of the extruder..
And I used a length of the smaller drag chains I replaced for the y axis. So all moving wires are inside of drag chains..
