03-19-2014, 03:46 PM #1
- Los Angeles
- 112
Reducing materials used during a 3D print
I have worked on my 3D models to reduce the amount of vertices and adjust the wall thickness, etc to save the amount of print materials used. I want to use my materials as efficiently as possible.
Do you guys have any tips to reduce the amount of material used in a 3D print in a 3D model?
03-26-2014, 01:22 PM #2
- Los Angeles
- 112
Any thoughts?
03-26-2014, 06:21 PM #3
- 462
Generally just the fill density setting in the slicing software. In the design stage, looking at where strength is needed and removing material where it isn't.
New member with print issue
