I will post the OneUp in just a little bit, all the parts are basically the same though. ทางเข้า gclub
Just came here. One quick question. What are you using for the frame? When I used 1/4" MDF I needed the full 70mm (or close to it). When i got the new version I was able to use 2" screws, which is about 50mm. It's tight but it fits. That is with 2.7mm thick laser cut plywood.
