Thread: Trouble slicing large stl file
03-13-2017, 05:37 PM #1
- Mar 2017
Hello, I am new to 3d printing and I am having problems slicing my file. The progress bar gets filled up and then it says 0 min to print which is obviously incorrect. I assumed the polygon count was too high so I used decimate to lower it by about 30-40% which helped cura slice it but removed so much detail that it was not helpful. The file called "smallest4layer" is the original stl file that I am trying to stack on top of itself a few times to create a filter, but I am unable to slice even the 4 layer version. The file called "smallest4layerdecimate" is the same thing after using decimate which sliced and printed fine but was too far off from my original design. I am getting extremely frustrated with this, so any help would be greatly appreciated.
Thanks in advanceSmallest4layer.stlSmallest4layerdecimate.stl
03-20-2017, 06:07 AM #2
going to need your printer settings.
The individual parts are too small and while it slices in about 1 second in simplify3d. It's just blank as the cell walls are way way too small for my printer settings.
Without knowing what ridiculously small settings you're usig I can't actually get a sliced model.
03-21-2017, 02:46 AM #3
- Oct 2015
- 35
So if I've got this correct, you've got a 50x50x0.8mm geometry made up of lots of sections of 0.2-0.7mm.
I don't know which technology you are planning to use, but you are going to struggle with most of them at this scale, and if successful it will not be very accuratedetail-1.jpg
As CA said above, what settings are you trying to process this with? It might help us understand whether it's achievable.
Rich
03-23-2017, 07:01 AM #4
Hi Adam,
I am measuring your wall thicknesses at 0.02 mm. That is impossible to 3D print with current machines.
If you are using an FDM machine, take your nozzle size+0.05 mm for the minimum wall thickness to ensure good slicing.
Set the line thickness in your slicer also to somewhere around this value - sometimes setting it a bit lower makes for better prints.
Also use boolean-union functions to combine multiple meshes may make for better slicing. Send me a PM if you want me to help you further with preparing STL files.
