02-18-2017, 06:07 AM #1
- Feb 2017
3D printer (tronxy diy kit from gearbest) Dosnt get to the correct heat
Hi, Whenever I set my printer to lets say 210 degrees, it gets stuck at about 190, i have tried changing the fan settings, please help
02-19-2017, 01:21 AM #2
Well.... I'm not familiar with that printer, what software are you using to slice? Is it setting the gcode to the correct temp?
If all your settings look kosher, get out your trusty multimeter, and see what the current/voltage is at the hot end. Check the same at the board, make sure you're not losing power somewhere. Then check with the manufacturer and find out what the hot end should be pulling. If it's not close, then you have a hardware issue.
But I'd guess it's a setting somewhere.
