02-07-2017, 03:49 PM #1
- Dec 2016
- 9
Viewing objects grid with no angles on objects
Hi guys
I've been playing around with AD123 design and I'm having an annoying problem viewing my work. I need to be able to set an object down on the grid and see it completely birds eye when looking at the grid from the top. I can't tell if my objects are aligned in the right spots but the angle to the parts keeps me from being able to do so. Every time I think I have something perfect then I go to pan around and they aren't even near where they are supposed to be.
02-07-2017, 09:45 PM #2
I'm really not sure exactly what you're asking, but maybe some pics would help?
From what I think you're asking, anytime I have issues (In SU) aligning something to a position, I create a new object at the location I want, and then drag the main object to it, then delete the temporary object.
02-08-2017, 02:23 AM #3
- Dec 2016
- 9
Ok i guess i meant between the two view modes. Orthalocical or what ever. Im trying to learn more on how to stuff and spent a couple hours adding cylinders for screw turrets on an altoids case. But im having a problem there too.
Is there a way to widen or thicken walls of a premade object like a box? The cad jockey that created left the OG object left walls at only like .6 thickness and it tore apart trying to remove it from the bed. Its literally translucent!!!!
02-08-2017, 02:31 AM #4
