01-06-2017, 11:24 PM #1
- Jan 2017
- Dallas, TX
New guy with a question. Bowden or direct drive extruder on Prusa kit?
I'm waiting for my new Prusa i3 kit to get here from China. This machine appears to have a direct drive extruder. I have the parts laying here to replace the direct drive with an E3D clone hotend and Bowden type extruder.
I understand the Bowden setup will give me lower weight on the carriage for the hotend. But you sacrifice some filament to the length of the feed tube.
Am I getting ahead of myself or is this a worthwhile upgrade to add while assembling the machine from it's kit?
Thank you.
TW
01-10-2017, 10:10 PM #2
- Honolulu, HI
- 199
You might try the direct drive first. Seems like Bowden came about for delta printers because of weight. I don't think that weight should be an issue with the Prusa and you won't really get an advantage over the direct drive.
06-04-2017, 10:44 AM #3
stick to direct drive. Lets you use flexible filaments.
doesn't make any noticeable speed difference either.
06-04-2017, 01:46 PM #4
Bowden drive causes a number of issues. The only benefit you get is slightly less weight at the nozzle. But for all of the extra issues that come up, I'm just not a fan of Bowden drive.
