Quote Originally Posted by DarkAlchemist View Post
Well, PTFE tubes are dirt cheap so that was never an issue. Hell, so cheap you could easily replace it after each print but seriously I would just change it out after each oil change, lol.
Where have you found those MK10 nozzle sizes for that low of a price and how was their quality? I literally just purchased an entire e3d v6 and volcano (Chinese knock off) with 5 nozzles, the fan, the shroud, the v6 nozzle, two 40w heating cartridges and 1 3950 thermistor for 10 dollars AND the quality floored me. I was expecting garbage (like my last one I purchased last year) and I have to give it a 9/10 and that is saying something. Of course it uses MK8 nozzles which I actually like because they are so cheap. 0.2mm to 1.2mm is what I purchased in varying sizes too.
Where did you get the knockoff hot ends? How are they working for you now? I am considering getting the E3D V6. Does it work with the Qidi Tech no problem? From what I have heard, the knock off hot ends still have a PTFE insert and do not allow you to go to the higher temperatures for nylong. For that you need an all metal hot end.
