Results 3,801 to 3,810 of 4110
12-20-2016, 06:24 AM #3801
- Jun 2016
- Oklahoma
- 904
Anyone tried replacing the card reader on one of these? My card got bumped and broke the holder a bit. Spring and stuff have gone! It still works but you have to fiddle a bit to get the card right so it will see it.
I may just order a new board. I am wanting to try to make an angled holder for the control panel to make it easier to see so a spare would be good anyway.
12-24-2016, 07:27 PM #3802Editor in Chief
Bitsonline
12-25-2016, 09:30 AM #3803
- Jun 2016
- Oklahoma
- 904
12-26-2016, 09:52 AM #3804
- Jun 2016
- Oklahoma
- 904
Anyone using Slic3r with the Tech-1?
12-26-2016, 11:15 PM #3805
- Apr 2016
- 12
12-27-2016, 05:46 AM #3806
- Jun 2016
- Oklahoma
- 904
What is your setup? How do you convert from Gcode? I am using a GUI version of GPX which seems to work nicely - at least I think so!
I got a start script working pretty good but when it goes to do the first layer everything points to it being to close to the bed since nothing lays down. The primer line lays down great.
I have only recently started using Slic3r on my MK2 and for that it is pre-configured.
S3D works with no issue. I am trying Slic3r for fun and to learn more about it.
12-27-2016, 08:46 PM #3807
- Apr 2016
- 12
I used the scripts found here: http://www.3duniverse.org/2014/01/05...forge-creator/
The GPX Perl script tool some messing around with to get working. As soon as I export, it generates the x3g - no extra steps necessary. I have the exact scripts and GPX batch file on my laptop, I can pull them for you if you'd like.
12-28-2016, 05:39 AM #3808
- Jun 2016
- Oklahoma
- 904
12-28-2016, 05:55 AM #3809
- Jun 2016
- Oklahoma
- 904
I have seen this page and tried this on my Flashforge Creator Pro and got it going once then moved to other projects. I tried this for the QIDI and it didn't work so good. The main thing I found with his script is it really bangs the machine around.
I have a "working" script I have pieced together but the main issue I am having is once it goes to start the actual print it is like it is way to close to the bed. Maybe this is a slic3r issue and first layer height is different than S3D.
I don't know if this is just my first layer height or if the script is setting the initial height to low.
The purge and line across the front of the bed works great and the gantry moves "calmly"!! I can post my script later if you want to see it. Maybe I am missing something. I am new to some of this.
I am also using this for the GPX. http://markwal.github.io/GpxUi/
It is nice but I do get some cautions when it runs. I don't mind the extra step but would definitely be interested in your setup.
Thanks for the help!
12-28-2016, 05:49 PM #3810Editor in Chief
Bitsonline
