Results 1 to 10 of 13
12-16-2016, 08:16 AM #1
- Mar 2016
- Düsseldorf
- 9
After a perfect raft the first layer messes up
Hi guys,
my makerbot got a strange error since a while.
The printer prints the raft in a good quality and than suddenly messes up the first layer. Most of the time just the center of it.
It looks like the nozzle is too close to the platform, but why is it printing the raft and the "outlines" of the cube correctly?
If I don't stop the print it will print the rest of the cube normal and the bottom has the holes from the first layers…
Anybody knows why?
I print ABS on a Makerbot Replicator 2 with an upgrade heatbed.
Thanks
12-16-2016, 08:29 AM #2
- Mar 2016
- Düsseldorf
- 9
If you don't cancel the print it comes out like this.
12-16-2016, 10:01 AM #3
Having similar problems with ABS. The guys suggest I try PLA.
12-21-2016, 05:45 AM #4
12-21-2016, 06:23 AM #5
- Mar 2016
- Düsseldorf
- 9
Bildschirmfoto 2016-12-21 um 13.19.23.jpgBildschirmfoto 2016-12-21 um 13.19.32.jpgBildschirmfoto 2016-12-21 um 13.19.42.jpgBildschirmfoto 2016-12-21 um 13.19.59.jpg
I just used a new roll of ABS and the same settings and the effect almost didn't happen.
Can moisture cause that effect?
Thanks
12-21-2016, 07:11 AM #6
- Mar 2016
- Düsseldorf
- 9
this is the bottom of the cube with the new filament and same settings. It's much better, but still not perfect.
12-22-2016, 06:45 AM #7
Don't see anything obviously wrong with your settings. Form the photo it looks like material that gets too hot. If you were running PLA at those setting you'd get a finish like that...
Strange.
12-22-2016, 07:41 AM #8
Well, now that's interesting...
When I first tried "Replicator G" it used 220C for the extruder temperature. Makerware has been using 230. Perhaps I'll cut it back to 220 and see what happens.
12-23-2016, 05:53 AM #9
- Mar 2015
- Slovenia, Europe
- 76
Hi there
make First Layer Raft = 30mms
temp of Right = 230
Heated bed temp to 105
And don't forget to turn off FAN from 1 layer if you are printing with ABS
12-26-2016, 12:30 PM #10
- Apr 2016
- 120
Try increasing the bed - extruder gap a little. It looks like the slightly thicker first layer is catching on the extruder. Half a turn might do it.
Do you need to print a raft? I find with Buildtak I never need to. It keeps the print attached and with no warping.
